Modo Illuminate Node
mpaquin
I tried hooking up the Modo Illuminate Node into an Octane Mix material and it doesn't look like it works. Has anyone gotten it to work or figured out a workaround?
You can see the Illuminate node in action here, restricting a texture effect to areas in shadow.
Is there perhaps a screenshot missing in your msg?
mpaquin
Woops. Sorry about that. The narration is in German but it gets the point across.
https://vimeo.com/92881148
I'm sorry - but it's not particularly clear what you are trying to achieve. If you can send me a sample scene demonstrating the effect you are trying to get (in the Modo renderer) I can take a closer look.
Return to “Foundry Modo”
