Crashes with render regions in PV
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
sdanaher
A. OSX 10.11.6
B. Titan X (local) Titan X & 980 (slaves)
C. 40gb
D. Nvidia driver version 346.03.15f06
E. OctaneRender Standalone version 3.06
F. OctaneRender plugin version 3.06
G. Host application version, including build numberCinema R18.048
H. Render region position difference between LV and PV leading to crashes in PV: As far as I can gather since its intermittent, if a render region has previously been saved to the Render Settings then a different region created in LV and saved it will cause a crash when rendering to the PV (while the LV render is active). Usually resetting octane (R button in LV) before the PV render prevents it. Also noticed that the stored region sometimes does not correspond to the region dragged out in the LV when rendering to the PV.
Always rendering with slaves. It's been an ongoing issue across different versions.
I. no render log, but bugreport.txt attached
_BugReport.txt
(364.11 KiB) Downloaded 320 times
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
What happen without slaves?
sdanaher
Same. It crashes without slaves too.
can you capture a video for me? It's not clear yet how you get it.
sdanaher
will try, yes
sdanaher
Made a screen cap, will mail you the link...
sdanaher wrote:Made a screen cap, will mail you the link...
Thanks! I'm trying same ways but no crashes. Btw i'm on windows not osx. And i see that your crash is in octane dll not plugin. I'll check for osx tomorrow.
sdanaher
OK thanks Ahmet!
sdanaher wrote:OK thanks Ahmet!
It has been reproduced. I think it's only for OSX version and we'll check it. Thanks!
sdanaher
Ah fantastic! Look forward to a fix, it was driving me mad.
Return to “Bug Reports”
