Is it possible to save 16bit images. Whenever i choose 16bit *.iff images end up 8bit...
Is there a solution?
Cheers, Max
16 Bit PNG from Maya?
C. RAM Capacity (i.e. 6 GB)
- Jolbertoquini
- Contact:
better to use exr 16bit then? is smaller size so would be large better then 16bit png's. but also keep in mind if use tonnemapping with PNG is pointless to save 16bit cause of the tonnemapping is clamping all at 8bit.just make sure you are working without tonnemapping and highlight compression this clamp you range on the files.maepopaxe wrote:Too bad!
who needs 8bit in production?
Best,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
