can't login
ThomasR
Everything was working fine ten minutes ago. Had to restard Cinema4D and suddenly I get the login popup and the "could not connect to sso server" message...
Is it a problem running daz and cinema licenses at the same time?
mojave
Running multiple plugins should be fine, this error usually shows that the Octane plugin's host application cannot access the Internet, usually due to an unstable connection, a firewall rule blocking it or incorrect proxy settings.
