Z-depth blank when saved as EXR
splittmatt
Hi.
Is there a problem with EXR z-depths?
When I'm rendering I can see the z-depth pass in the render window ok and if I save it as a single image it's fine. But when I save a bunch of passes out as an EXR the z-depth layer always comes out blank?
Any ideas? Am I doing something wrong?
Thanks.
Matt
Win 11. Intel I-9 14900K. 64Gb. RTX 4080 Super.
What plugin version are you using pls?
splittmatt
3.5.3.78
3.5.3.78
Z-Depth is a float per pixel rather than an RGB pass - so I think you will need to use the Octane Photoshop plugin to see this pass correctly.
Return to “Rhinoceros 3D”
