Vignette as a layer ?
richardyarlett
I am rendering out a scene with a Vignette of 0.5 applied. I am rendering it with Layers, of several Light Passes and a Post Processing Pass. When I compare the straight output with the comped output, I finally worked out why my comped is a bit brighter. It is because the 0.5 VIGNETTE has not be added. Is there no way to layer in just the Vignette back over the comp so it matches the straight exactly ?
paride4331
Hi richardyarlett,
I think the best way is to make it in post with software like photoshop.
Regards
Paride
Return to “Autodesk 3Ds Max”
