Hey there,
So I guess this is kinda simple question- how do I fit UVW map to bitmap? In 3ds max this feature is called "Bitmap Fit" under UVW options.
Because when I use non square textures they get cropped if using box projection. So how do I fix this? Ofcourse you can try transforming/scaling image or uvw map manually but it's a pain in the ass to get it right.
Thanks!
P.S. C4D user here.
How do I fit my UVW to bitmap?
If I get you right.. you just want to project a texture without unwrapping your object?
Yeah you can try to do a box/flat project or whatever works best and then scale and move the texture. Sometimes this works, depending on your object/texture. If you want to add displacement maps later you are screwed anyway as these only work on unwrapped objects/UV projection. Best is probably to just unwrap your object properly.
If you aren't that comfortable unwrapping objects I can recommend Unfold3D. I use this all the time. It's super simple and has saved me many times. Look up some tutorials on Unfold3D on Youtube and see if its something for you.
C4D R18 / C4D R19
AMD Ryzen Threadripper 1950X — MSI X399 Gaming Pro Carbon
MSI 1080 Ti FE — 2 x PALIT 980 Ti Super Jetstream
Corsair AXi 1500W — Corsair Vengence 32GB 3000MHz LED White
- MantasKava
Yes I want to project a texture without unwrapping it. And for archviz modeling I think you can get away without unwrapping like 90% of the timesChrmez wrote:If I get you right.. you just want to project a texture without unwrapping your object?
So the only problem is that theres alot of textures I have that is non square aspect ratio (like all the wood textures often is longer than wider) but without re-scaling UV map these images gets cropped, and as I said adjusting UV's scale manually to fit the image perfectly is a pain in the ass.
Yeah I know about unfold3d and I own that, but usually I model simple things and I don't want to spend some extra time for exporting/importing things just to have my flat UV map the correct aspect ratio I want.
I really think there should be a simple way to achieve this? As I said, 3ds max has this feature I'm looking for.
- MantasKava
And by the way, in the project texture node there is a "external transform" input which i thought would be the feature I'm looking for, but when I click it and select my image it only creates bitmap node inside the material editor. What's up with that?
Planar/Box projection and "Fit to Image" command.
- MantasKava
Where can I find this command?aoktar wrote:Planar/Box projection and "Fit to Image" command.
- MantasKava
Nevermind I found it !MantasKava wrote:Where can I find this command?aoktar wrote:Planar/Box projection and "Fit to Image" command.
Though it is kinda weird that it doesn't work in cubic projection mode.
