motion blur on alembic imports
derekhanz
Doesn't seem to work in my scene. This is a massively important feature for me.
Is it supported?
david-maus
I have the same problem. If i export to alembic with vertexmap enabled in exportdialog the motionblur is working on a clothobject after reimport... but for example a teared cloth as alembic is not possible with motionblur. I have seen in the new test 4 build is support for vector speed motion blur:
viewtopic.php?f=85&t=60380
Is it possible with that option? What is the correct workflow to get the vertexmap/tags/velocityinfos from a teared cloth surface?
See this post and read release notes.
viewtopic.php?f=85&t=59657&start=30#p305605
It may work or not don't know. Unfortunately nobody posted feedbacks about this feature. I cannot know or test everythings on every scenario.
bagel
It does work. I use RealFlow fluid simulations.
On your mesher make sure that VelocityX, VelocityY, and VelocityZ are selected. Then once your sim is all configured and mesher is tweaked appropriately, you can right click the mesher object (not the parent, that won't work!) and select bake to alembic and delete. Let it run through the sim and voila! Then in the Octane object tag, under the motion blur tab, you need to select Vertex Speed, tick the drop down, and drag the appropriate vertex map into each field. Motion blur works fine.
Presumably, whatever is generating your cloth mesh can be baked to alembic as well.
Also, you can bake volume mesher in R20 to alembic, but I haven't figured out how to export vertex speed as well.
I hope that helps a little. I know you're not using RealFlow per se, but it's good information. You have to be able to have a method to generate the vertex maps prior to exporting.
