OctaneRender® for Maya® 3.06 (test 4) - 10.12 [OBSOLETE]
This is a TEST version, so be prepared to have some issues. Don't use it for production.
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems, 2015, 2016, 2016.5 and 2017 64-bit on Linux operating systems, and 2016, 2016.5 and 2017 64-bit on OSX operating systems (including and above 10.9).
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of Octan eRender™ Standalone on your machine.
viewtopic.php?f=33&t=60354
  • Implemented 3.06 TEST 4 engine support.
  • Minor fixes and improvements...
Windows
DOWNLOAD
OctaneRender for Maya 10.12
Linux
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 10.12 Linux
OSX
Installation:
- Just run the autoinstaller file.
DOWNLOAD
OctaneRender for Maya - 10.12 OSX
calus
Minimum limit of expected exposure have been changed to 0.001 in 3.06 TEST 4
Pascal ANDRE
