OctaneRender® for Maya® 3.06 (test 3) - 10.11 [OBSOLETE]
This is a TEST version, so be prepared to have some issues. Don't use it for production.
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems, 2015, 2016, 2016.5 and 2017 64-bit on Linux operating systems, and 2016, 2016.5 and 2017 64-bit on OSX operating systems (including and above 10.9).
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of Octan eRender™ Standalone on your machine.
viewtopic.php?f=33&t=60015
  • Implemented volumes support in Octane animated scene export ("alembic inside" mode).
  • Other fixes and improvements...
Windows
DOWNLOAD
OctaneRender for Maya 10.11
Linux
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 10.11 Linux
OSX
Installation:
- Just run the autoinstaller file.
DOWNLOAD
OctaneRender for Maya - 10.11 OSX
calus
Pascal ANDRE
calus
:D
You also implemented in this release animated visibility support in the ORBX exporter ...
Some Maya users were not using the plugin for years because of this issue...
They had to export their scene trough Maya builtin Alembic and set materials in standalone.
This deserves a better release Log than just "Other fixes and improvements" ;)
Pascal ANDRE
Jolbertoquini
Hi Jim,
I have a bug the visibility for hairs are not working I can't hide on a layer or set visibility off Octane still rendering with the hairs.
Everything seam to work mesh instance, fluids but not hairs.
Best,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
