Adding Nodes
slimer
Can anyone tell me how to add a Color Correction Node inside the Node Editor?
The manual says that the options should pop up when you move your mouse over to the left side of the window?!
Nothing happens when I do that. Is there a different way to bring up that menu in the Rhino plugin?
Thanks.
Hi - can you point me to the manual page where this is described pls? To add a color correction node, click the pin in the tree where you want it, then change the Node Type to Color Correction (bottom of the panel).
Return to “Rhinoceros 3D”
