OctaneRender® for Maya® 3.06 (test 3) - 10.6 [OBSOLETE]
This is a TEST version, so be prepared to have some issues. Don't use it for production.
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems, 2015, 2016, 2016.5 and 2017 64-bit on Linux operating systems, and 2016, 2016.5 and 2017 64-bit on OSX operating systems (including and above 10.9).
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of Octan eRender™ Standalone on your machine.
viewtopic.php?f=33&t=60015
Quick fix release
  • Implemented a support of Bump/Normal maps in material converter.
  • Minor fixes...
Windows
DOWNLOAD
OctaneRender for Maya 10.6
Linux
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 10.6 Linux
OSX
Installation:
- Just run the autoinstaller file.
DOWNLOAD
OctaneRender for Maya - 10.6 OSX
Tharso
Single material coversion is not working yet?
calus
Tharso wrote:Single material coversion is not working yet?
that's weird "convert selection material" doesn't fail here,
but I can see it doesn't work the same as "convert all materials",
the first option in render setting is not respected...
Also, I see other weird things in the converter, but need more testing...
Pascal ANDRE
