Octane Sky
dath
Hi guys, I've successfully achived to hide the sky from render, but it's still visible trough transparent objects like glass. I there a way to make it unvisible in transparency? cheers.
calus
If want to see something else in refraction, use a second environment node plugged in visible environment input of the rendertarget, and enable refractions in visible environment section.
If you want end refraction to be transparent, enable "affect alpha" in your specular materials.
Pascal ANDRE
dath
calus wrote:If want to see something else in refraction, use a second environment node plugged in visible environment input of the rendertarget, and enable refractions in visible environment section.
Great! Thank you!
