OctaneRender® for Maya® 3.06 (test 3) - 10.3 [OBSOLETE]
This is a TEST version, so be prepared to have some issues. Don't use it for production.
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems, 2015, 2016, 2016.5 and 2017 64-bit on Linux operating systems, and 2016, 2016.5 and 2017 64-bit on OSX operating systems (including and above 10.9).
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of Octan eRender™ Standalone on your machine.
viewtopic.php?f=33&t=60015
  • A couple of bug fixes and improvements...
Windows
DOWNLOAD
OctaneRender for Maya 10.3
Linux
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 10.3 Linux
OSX
Installation:
- Just run the autoinstaller file.
DOWNLOAD
OctaneRender for Maya - 10.3 OSX
calus
- Triplanar setup works. :)
- LiveDB doesn't crash Maya anymore, but there's a bug with file texture and UV projection:
when in a LiveDB material, the ImageTexture node use an UVprojection,
the ImageTexture node is created but not connected to the material.
(when ImageTexture don't use UVprojection it is correctly connected to material)
- octaneMatConverter command is still broken.
The command is processed but nothing happen.
octaneMatConverter -ca;
// Converting surface shader of shading group "blinn1SG": //
// Converting surface shader of shading group "phong1SG": //
// Converting surface shader of shading group "phongE1SG": //
_
Pascal ANDRE
