Separate Reflections, Light and background.
Fabrice
In an outdoor scene I'd like to separate the reflection environment from the lighting and also from the background picture.
For example :
The scene is lit by a sun+sky
The background is a JPG file
The reflection come from an HDRI file
How to achieve that please ?
Octane 3.04.5 + 3DS Max 2014 plugin (GTX 980 Ti + GTX 780)
Hi Fabrice,
- enable multi pass beaty Environment and Reflection
- enable Alpha channel in the kernel settings
- set the sky + sun as primary environment
- set the HDRI as Visible environment with only reflection ticked
- compose the layers in your prefered image processing app.
voilà
Fabrice
Thanks again for your answer Beppe !
I'm sorry I'm an octane beginner...
How do you set the sky + sun as primary environment
and set the HDRI as Visible environment with only reflection ticked ?
I don't know where those options are...
Fabrice
Hi Fabrice,
sorry, which version of OctaneRender are you using exactly?
Standalone or integrated plugin?
Fabrice
Yes :)
paride4331
Hi Fabrice,
Here are some links may be helpful:
viewtopic.php?f=27&t=41933&start=10#p306069
viewtopic.php?f=9&t=59392&p=304010#p304010
In Octane 3dsMax plugin Discussion forum you will find a lot of information from users available to give you advice.
viewtopic.php?f=27&t=59549#p304625
Regards
Paride
Fabrice
Thanks a lot Paride, seems very helpfull!
