OctaneRender® for Maya® 3.06 (test 3) - 10.2 [OBSOLETE]
This is a TEST version, so be prepared to have some issues. Don't use it for production.
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems, 2015, 2016, 2016.5 and 2017 64-bit on Linux operating systems, and 2016, 2016.5 and 2017 64-bit on OSX operating systems (including and above 10.9).
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of Octan eRender™ Standalone on your machine.
viewtopic.php?f=33&t=60015
  • Fixed a crash when exactly 2 UV sets were used with motion blur disabled.
  • Material converter improvements...
  • Other fixes and improvements...
Windows
DOWNLOAD
OctaneRender for Maya 10.2
Linux
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 10.2 Linux
OSX
Installation:
- Just run the autoinstaller file.
DOWNLOAD
OctaneRender for Maya - 10.2 OSX
Tharso
converting materials is not working on my side. I have a bunch of phong materials.
tks
calus
Tharso wrote:converting materials is not working on my side. I have a bunch of phong materials.
- Same for me, the convertMaterial command is broken, has no effect.
- Maya freeze when importing material with file texture from LiveDB/localDB.
- Maya freeze when adding a triplanar projection in a texture node.
Pascal ANDRE
