Render Progression Bar?
Greggers
Hi guys, is there a way to show a progression bar or a like hud display in the octane for modo render window, or anywhere as a matter of fact?
oh and does anyone know when the 3.6 3rd test build will be out for OS X, Thank you :-)
Hi - a progress bar is not currently available when you open the Viewport. Instead, you can check the samples progress in the Viewport status bar. You can also use the "octane.renderAndSave png8" command, which has a progress bar.
Greggers
Cheers Paul \m/
Return to “Foundry Modo”
