render bugs
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
RobotRumpus
I have been getting lots of render errors when rendering inside Nuke. I get a lot of duplicate frames and fluctuating sample rates. When I render as a frame sequence, I always get errors. If I render as a quicktime movie, it seems to work, though. The workaround I found is to add an extra quicktime render node and pass through it on my way to the EXR write node. This is the only way I can get Octane to render properly inside Nuke.
I also tried to export as OCS and ORBX, so I can render inside Octane standalone, but I am getting different errors with that, which I will detail in a separate report.
~Jason
specs:
Nuke 10.5
Octane v3.5.2.31
3.99 GHz Intel Core i7
32 GB 1333 MHz DDR3
EVGA GeForce GTX 980 TI
Mac OSX 10.11.3 (15D21)
nVIDIA web driver 346.03f02
CUDA 7.5.25
Hi Jason - can you pls send me a sample scene which exhibits this problem?
EDIT: I see you have already sent it to me! I will take a look.
Return to “Bug Reports”
