Z depth
BorderLine
Juanjo,
A problem with Z depth. I modify Z Depth Max (50), it's Ok in IPR but when i do the final EXR render, the Z depth is always to 0 .
juanjgon
Sorry, but I can't reproduce this problem here. At least with my (soon to be released) 3.06 test version the Z is exported fine. What version of the plugin are you using?
If you want to attach a scene with this issue, I could test it here.
3dreamstudios
I do not have trouble saving out Z in 3.05. I can save through Render Pass node 0-600+ depth passes. I don't save in EXR format though. PNG16.
You might try saving in PNG format to see if maybe there is something wrong with EXR or possibly the software your looking at the EXR in even. Good luck!
Return to “Lightwave 3D”
