Minimum hair thickness
FxDesign
Hello,
Is there a way to reduce the hair thickness behind 0.01 ?
I have a very tiny scene that need to render splines as hair, but it should be at least 0.005
Thank you
You can manually revise it from objecttag.res file. I'll show exact place when i returned.
FxDesign
Thanks Aoktar, I think I've found it.
Question, if I use a render farm, will this new setting of objecttag.res should be modified too in their machines ?
