Fog in Cinema 4D with Octane V3
SkateStyle
Hey guys,
Is there anyone, who knows how to create fog / mist in Cinama 4D with Octane V3?
I created a forest scene and want to give it a look like this bluish fog: http://prntscr.com/egdl60
It would be awsome if there is someone, who can help me :D
~ Skate
toto79
If you only need the blue haze in your scene you can use the Z pass and some comp to add that effects, It will be really fast and won't add render time.
https://docs.otoy.com/#cinema-4d-v3-plu ... er-z-depth
WIN 10 64bit | Asus X99 Delux USB 3.1 | i7-5830K 3.5 Ghz | 32 GB RAM |1200 W PSU | 512 GB SSD |
2 x PNY - GTX 980 TI
1 x PNY - GTX 1070
C4D 17.55 | Octane 3.06.2 | GeForce Driver 378.49
Hi SkateStyle,
if yoy don't want to use the Environment medium, or VDB volumes, or compositing a Z-depth pass, another solution is to place several big planes or concentrical cylinders with a diffuse light blue material and very low opacity.
SkateStyle
toto79 wrote:If you only need the blue haze in your scene you can use the Z pass and some comp to add that effects, It will be really fast and won't add render time.
Thank you! This realy helps me!
I thought Z-Depht can only be used for DOF ;D
Thanks!
SkateStyle
bepeg4d wrote:Hi SkateStyle,
Okay thank you!
But how to do it with an Environment medium... for me its not working :o
