Hi There,
This option "disable partial alpha" is missing on Octane imager, so when we use render layer the alphas are unpremultiplied.
really a big problem because we can use the maya plug to render older projects with Octane render layers.
Best,
JO
URGENT: "disable partial alpha" [SOLVED]
C. RAM Capacity (i.e. 6 GB)
- Jolbertoquini
- Contact:
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Actually the
As you have this second wrongly labeled
and this is why the image seems to have alpha "unpremutliplied" even if the
The
(so the option is not needed most of the time)
Thanks Jo, to have highlighted this mistake in the plugin and the confusion coming with it...
is in the plugin but with a wrong label
neutral response
option enabled, you have in fact the disable partial alpha
enabled,and this is why the image seems to have alpha "unpremutliplied" even if the
premultiply alpha
option is enabled...The
option have been introduced in Octane3 core to help for this issue : viewtopic.php?p=269484#p269251(so the option is not needed most of the time)
Pascal ANDRE
