OctaneRender® for Maya® 3.06 - 10.0 [OBSOLETE]
This is a TEST version, so be prepared to have some issues. Don't use it for production.
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems, 2015, 2016, 2016.5 and 2017 64-bit on Linux operating systems, and 2016, 2016.5 and 2017 64-bit on OSX operating systems (including and above 10.9).
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of Octan eRender™ Standalone on your machine.
viewtopic.php?f=33&t=59760
  • Implemented support of 3.06t2 engine. See info about new features in 3.06 standalone threads.
KNOWN ISSUES:
  • Triplanar texture is broken in 3.06t2 engine, so don't try to render it. It will crash.
Windows
DOWNLOAD
OctaneRender for Maya 10.0
Linux
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 10.0 Linux
OSX
Installation:
- Just run the autoinstaller file.
DOWNLOAD
OctaneRender for Maya - 10.0 OSX
calus
JimStar wrote:This is a TEST version, so be prepared to have some issues. Don't use it for production.
So why is it released in the releases (production) section ? _ :shock:
In my opinion this is looking for troubles,
this should have been released in the Testing (non-production) section :!: .... here: viewforum.php?f=125
Pascal ANDRE
calus
Material normals are completely broken in this version, not usable even for testing adaptive sampling. ____(except for adventurers *)
Actually I found what is the bug in the plugin:
Normal map have been modified in Octane to support other node input,(RGB inputs)
but this has not been adapted in the plugin ...
The plugin translate zero value normal map to black float !!! WRONG !!!!!
neutral normal map is PURPLE, so that's why normals are broken in every materials ....
* For adventurers it's still possible to workaround the plugin bug : plug a purple RGB (Red 0.5 Green 0.5 Blue 1) in every empty normal map inputs of every materials.
Pascal ANDRE
