Hello
Where can i found the 2-stage converter to download?
Is there any tutorial, or guide lines to follow?
Thanks a lot
Fábio
2-stage converter
if you're using latest version just go to render setup/tools activate conversion system, restart max, it will automagically translate the old materials upon loading of scene
3dmax, zbrush, UE
//Behance profile //BOONAR
- FabioHartmannFernandes
Thx a lot for your reply.
I am using tha 2.26.1 - 2.23 version.
Could not find the conversion system that you mentioned.
Is there any other option?
Fabio
Fabio
Hey otoy team...
Need some help here guys
Have a huge scene made with the older version, and it would be a huge set back if i could not convert the hole scene at once... i am in a tight schedule
Fabio
Fabio
- paride4331
Hi FabioHartmannFernandes,
Octane V3 conversion system supports scenes from 2.23.2 - 1.9 to earlier.
Could you kindly provide some more information?
Regards
Paride
Regards
Paride
Hi Paride
Thanks for the reply
I am using the 2.26.1 version, but the scene was made with 2.23 version.
When i open in the new version, all maps disapear.
I heard that there is a two step conversion app to upgrade for newest core engine.
Can you give me a hand?
Thanks a lot
Thanks a lot
- paride4331
should not be any difference between 2.26 and 2.23 except the Octane Updated SDK to support Pascal GPUs.
viewtopic.php?f=80&t=58162#p298938
Are you sure your issue depends on 2.26?
Regards
Paride
Regards
Paride
Hello Paride
I made the scene in version 2.23.2-1.9 and installed version 2.26.1-2.23.
When I open the scene, all maps disappear.
I reinstalled version 2.23.2-1.9 and everything returns to normal.
Fabio
Fabio
- paride4331
Hi Fabio,
thanks for your report.
Regards
Paride
Regards
Paride
