Modo 10.2v1 doesn't see Octane plugin
simsen
Hello,
I've just installed Octane V3 ( 3_3_3_112). By default, Octane install the plugin in the Modo 901 folder. Modo 901 sees the plugin, but 10.2v1 does not.
Any idea to solve this probleme ?
thanks
simsen
forget it, I've just found how to fix the problem
May I suggest updating to release 3.5.3.116 of the plugin, since it is more robust than the version you are using.
simsen
Thanks Paul.
J've just installed it. Now I have to wait, since I bought the upgrade less than 24 hours ago, it's still not active...
studio3lhd
can you post how you've solved this. The octane installer doesn't even write anything for me.. :(
Octane for Modo (v 2.22.2.68), Modo (801 sp4);
2 x TITAN Black,
I7, 32GB RAM.
If you have an issue, can you pls post your system specs, plugin version and modo version as requested at viewtopic.php?f=34&t=55078 and I will help you.
Return to “Foundry Modo”
