Looking over the console output - I can see the exporter is sampling temporally at whole frames and in-between (of course depending on how many time samples per frame are selected in the render settings).
Say - for example - with my current settings (1 time per frame, shutter half FPS, shutter alignment BEFORE) when rendering frame 15, it exports time samples at frame 14, 14.5, 15.
My question is: Is it possible to somehow set the sampling to occur at frames: 14.5, 15, 15.5 ?
I tried different shutter-alignment and time-shift settings but the change happens only on the mid-frame sample - i.e. 14, 14.8, 15, etc.
Also it would be very convenient having a possibility to disable motion blur caching for specific Octane ObjectTags when sequence rendering. Right now I had to work around this by writing a script that keeps rendering single frames one by one separately, which is sub-optimal at least.
B
