GPU usage
archiform3d
I am using the render queue to process out animations, have the priority for the GPUs set to high, yet it only shows that my GPUS are running at around 45%-65%. I would love for them to be working harder. Any ideas?
ChrisMills
Untick "Use Priority" to let your GPUs run unthrottled.
archiform3d
ChrisMills wrote:Untick "Use Priority" to let your GPUs run unthrottled.
That didn't make any difference. I am starting to believe that the issue may be how the GPU usage and temperatures are calculated/displayed. For example, it is showing the wrong temperatures on the cards, mixing them around. If I have less cards installed the usage percentage is higher.
archiform3d wrote:
ChrisMills wrote: it is showing the wrong temperatures on the cards, mixing them around.
It should show in correct order if you're using latest versions.
