environment textures
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
dreif
Hi. I'm running into an issue when using the environment textures together. When I set them up everything renders correctly.
But one texture or the other will be given the 0-prefix (non-user) and will be removed from the .blend file when saved and closed.
When one texture or the other is open in the node editor the other will be given the 0-prefix. When I open the file for continued
work I have to rebuild the texture that was removed.
Win 7x64/GTX TITAN/Amd Phenom IIx4 955/16gb (The render tra la la)
pegot
Is your problem related to this (see below link). If so I had similar issue. Per JimStar fix is to: "enable the 'Save this data-block even if it has no users' switch in Blender's texture UI for any textures referenced by Octane environments."
viewtopic.php?f=114&t=56889&p=292982#p292215
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
dreif
That seems to be it, I missed that post. Thank you pegot for the informaton! :D
Return to “Bug Reports”
