OctaneRender® for Maya® 3.05.3 - 9.36 [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems, 2015, 2016, 2016.5 and 2017 64-bit on Linux operating systems, and 2016, 2016.5 and 2017 64-bit on OSX operating systems (including and above 10.9).
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of Octan eRender™ Standalone on your machine.
viewtopic.php?f=24&t=58640
  • Implemented batch command line flags to use all local GPUs and all available network slaves.
  • Minor fixes and improvements...
Windows
DOWNLOAD
OctaneRender for Maya 9.36
OctaneRender for Maya DEMO 9.36
Linux
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 9.36 Linux
OctaneRender for Maya DEMO - 9.36 Linux
OSX
Installation:
- Just run the autoinstaller file.
DOWNLOAD
OctaneRender for Maya - 9.36 OSX
OctaneRender for Maya DEMO - 9.36 OSX
calus
2 new flags in command line batchrender :)
OctaneRender Settings:
  -agpu   boolean       Use all local GPUs for rendering
  -asl    boolean       Occupy all available Octane network render slaves for rendering, no matter which of them are enabled in the locally stored net-rendering setting.
Pascal ANDRE
nedan
:D Thanks alot! :D
Jolbertoquini
Hi Jim,
For the volume gradient I can't plug any colour and is not working for the Maya fluids.
I know is a working progress but it was working before. Should I use a other version of the plug?
Best,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
calus
Jolbertoquini wrote: For the volume gradient I can't plug any colour and is not working for the Maya fluids.
@JimStar,
I confirm the Octane Volume Gradient is broken, colors are not rendered.
This is because of the texture component you added to the compound attribute.
Sorry if I was not clear enough previously :
In standalone we can connect textures in the gradient node, not in the volume gradient node.
Pascal ANDRE
