Proxy selection
Jasonr
Is it possible to be able to have lamps for proxy selection and not just objects?
This would have been really useful and time saving as lamps are a different category inside archicad (because of their lighting attributes)
You can save a lamp as an object and use it but in order to cancel that step it is necessary for Octane to be able to use lamps as proxy right away.
I have no idea if this is difficult to implement but it is a suggestion.
Thank you so much.
ASUS Z10 PE-D8 WS/2 x XEON E5-2680 V4/64GB RAM/1xQuadro M5000/2x NVIDIA GTX TITAN Pascal/ Windows 10/ Archicad 20
I'm not sure if this would be possible or not. The proxy system relies on a number of parameters obtained from the ArchiCAD API specifically for Object items, and I doubt these would be available for lamps. But I will take a closer look when doing the next release.
Jasonr
Thank you Paul for yoy direct support.
