Image Seq as HDR?
LFedit
I got this working in C4d, and in the Modo preview render, but can't get it to work in the Octane for Modo Render. Is there a special way to get an image seq as an hdri? Mine just went all white...
Thanks!
Hi - I'm not sure exactly what you mean here.....do you mean when rendering an animations inside the OctaneRender for Modo plugin? Which version of the plugin are you using pls?
LFedit
Sorry I think I posted this in the wrong spot. But here is my version: OctaneRender 3.03.4 (3030004)
I am using an image seq as an hdr for my environment. I am using it to capture the reflections from the original shot. And the reason I have it set as the hdr is because its for VR so I use the hdr as a 360. It lines up great and the reflections match perfectly. But I need the reflections to move, which is where I use the image seq as my HDR environment.
Like I said, in the preview render it works, but then in octane it wont. In c4d in the environment settings, you can check "animated" and set the amount of frames.
Hope I explained that better,
Thanks!
Specifically where is it not working pls? When opening the viewport, rendering an animation inside the plugin, or when exporting to ORBX/OCS?
Also - make sure you are using the latest test release (3.5.3.116), since some issues related to animated environments were fixed there.
LFedit
Just in the plugin in the render window. I will give the new plugin a go. Just difficult for our studio because then we all have to keep the latest versions. Hard to switch between projects. But I will let you know if it gets fixed when we feel comfortable upgrading.
