Crash on orbx export
Jasonr
Are there any certain cases that an export to orbx keeps failing?
The limitation of the plugin to an analysis less than 8k is preventing a direct export to a loadable cube map
so it becomes necessary to export to orbx and use the standalone version.
During the export of a certain file the plugin crashes archicad.
I can send you the file so you can try and reproduce the error.
I am afraid that this may happen again to other files.
Thank you.
ASUS Z10 PE-D8 WS/2 x XEON E5-2680 V4/64GB RAM/1xQuadro M5000/2x NVIDIA GTX TITAN Pascal/ Windows 10/ Archicad 20
Hi - can you send me the pln which is causing ArchiCAD to crash during the export pls? And which release of the plugin are you using?
