Mass baking. Is it possible?
PAQUITO
This days, I´m doing a lot of baking in complex scenes, which implies manually changing the baking camera id on each uvmap. Is it possible to set the list of ids so it automatically bakes and save one after another until it´s finished?
AMD FX8350 8 cores. 16GBs RAM
GTX690
Win8 64.
mojave
At the moment there isn't a magic button for that but it can definitely be done.
Beppe shared a while ago a Lua script that creates a setup the scene for baking, so you can just switch your baking camera's baking Id to render the specific baking group you need.
viewtopic.php?f=73&t=57252&p=294101&hil ... ph#p294101
You may use this in combination with a batch render job, to which you may add a number of render targets.
I hope that helps.
