I'm wondering if there is a solution to change the octane attribute on a group or layer, to override and affect all the objects inside.
Or a way to apply the same setting on all the selected object?
For instance, if I want to turn of the camera visibility on multiple object at the same time. It will be useful.
Maybe there is a Maya solution but I don't find the octane attributes in the attribute spread sheet window.
Any idea?
Thanks!
Octane Attributes on group or layers
You can just change these attributes on multiple selection in the channel box (unless you use maya 2016.5, channel box is broken in 2016.5)
So you can create sets of selection, if you change often this attributes, for several groupes.
Pascal ANDRE
This free tool may be exactly what you were looking for
https://www.highend3d.com/maya/script/m ... r-for-maya
http://vimeo.com/203672805
Pascal ANDRE
