I normally use Direct Lighting Kernel with Ambient Occlusion. However I have a scene I really need full global illumination. I tried Diffuse and it's nice but for low lit areas the noise takes FOREVER to clean up. With well lit areas it's not bad really (time wise).
Are there any tricks to getting Diffuse or Path Tracing to be faster for low lit areas to clean up the noise?
I was even thinking of doing some crazy pass of LW native Radiosity CLAY SCENE and compositing in AFX or something. Not sure it would even work...just looking for wasy to improve noise and time...I'm sure no one ever wants to do that! lol.
Thanks for any thoughts.
Share your tricks for faster rendering
- LightwaveGuru
- Contact:
use for example neat video 4 for cleaning up noises. it make no sense to kill all noize with brutforcing by the renderer....
hint: take massiv down the GI Clamp...under 10
https://www.neatvideo.com/
snip lwugru
snip lwugru
http://www.neotek.laboratories.de or http://www.youtube.com/c/Lightwaveguru or http://www.facebook.com/safarifx 4x Titan X 12 GB watercooled / 6x 2080 ti air cooled / 2x 980 ti watercooled
- 3dreamstudios
I didn't see much difference between the default (lot's of 0's) and 3-6. I must be doing something wrong, or that setting wont help what I'm seeing in my scenes. I'll look into what that setting is doing and go from there. Thanks for pointing it out.LightwaveGuru wrote:use for example neat video 4 for cleaning up noises. it make no sense to kill all noize with brutforcing by the renderer....
snip lwugru
Here's one:
By making all of the outer walls in an interior emit light you can boost your render times by ~70%+. The gotcha to this one is that you have to be careful not to rely too heavily on it, or else it can make the environment look flat or too inaccurate. Octane favors scenes with balanced quantities of light, which is why this method works and part of the reason why daylight scenes render so much faster.
Below shows an image with identical Octane settings and the same number of samples (100), the left image was lit the normal way, the image to the right has emissive walls.
- BorisGoreta
- Contact:
You should set caustic blur to 100% or higher and lower GI clamp to around 1.0.
- 3dreamstudios
Can someone tell me what the difference between setting the sliders for glossy, diffuse and specular are compared to this GI Clamp. As far as I can tell the GI Clamp, clamps those above values? I did not see a difference when I tried 1000000 (default) and 3-5. You'd think that would show "something"
Thanks.
Thanks.
