Light Linking and/or More Light Options
Tag12345
Probably the most important feature that Octane could use would be Light linking.
I had issues when I was first introduced to Octane seeing as you could only use the area light, but I then got over this because the area light has options for IES and different area light modes, which is a pain still, but much better than not having anything at all.
Though, with Light linking, this is the only way to really have good artistic lighting in Cinema 4D (and other applications) , and something most C4D users are used to and want (and this can be said with other programs that allow the ability to be very specific with how lighting is done).
Being able to exclude objects that you dont want to be lit and include others is extremely powerful and allows for different types of layering effects as well and just pure freedom of light placement,etc.
I would love to see this implemented soon!
We need more light features!
If this cant be done, my other alternative was to at least have the ability to not see the lights in reflections.
I use Octane with the C4D plugin, and it seems that theres no option to not see the lights in reflections.
But I think the Light Tag could use more options for visibility rather than just the opacity, global visibility and the off switches for light shadowing.
Im mainly talking about reflections and being able to turn off reflections of these lights. I noticed that the lights act strange when they dont have opacity on. Instead of opacity being a slider to very how you want the VISIBLE light to work, it functions for both visible lights and Non - visible by the camera.
This is an issue.
As far as I can see, theres no way to have your light be 'invisible' (therefore no light reflections) and also produce the same effect as if it wernt (as far as light mechanics).
This is a test, with General Visibility 100% -- Camera Visibility off, Opacity 100%
This is with those same setting and Opacity at 0%, i think Opacity should be linked to the light itself, either that or just add in an option to turn off lights in reflections
As always, Im still fairly new to everything Octane has to offer, and only come here when I cant find out how something may be done, so I may be missing something if theres another way around this.
Hi Tag12345,
I guess that your issue comes from the fact that your emission is not efficient if recessed or behind a transparent object.
Please, have a look at this other discussion, it's about noise, but it should work also in this case:
viewtopic.php?f=23&t=52982&p=266457&hil ... er#p266457
Tag12345
Its not behind the objects. They are lights I want to be Hidden, yet still light the scene.
Doesnt seem octane (at least plugin side, according to the C4D developer) doesnt have a way to Hide the lights in reflections/refractions in CORE.
You can hide light shadows and hide the glow or Opacity but not the Light emitter.
So Its more or less something that is needed. But this branches onto having the fuctionality to have the ability to allow lights to interact and exclude various objects. Its one of the many troubles Im having with octane as alsmost ALL renderers have a feature like this, BUT octane, both PB renders and not.
