IPR Freezing bug [SOLVED]
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
calus
IPR doesn't refresh anymore when launching a new IPR session while already using IPR with a render region.
To reproduce with any Maya scene :
1/ Disable Use Pick Focus region in the current camera (this will activate the render region mode)
2/ Launch IPR
3/ Draw a region in the render view
4/ Click on the IPR button
5/ Now IPR is frozen, unless you unable again Use Pick Focus region
When this bug happens, Octane is still rendering under-the-hood but stops to feed the renderView buffer with the updated render.
Pascal ANDRE
itsallgoode9
oh, man, this is what was causing my issue! I hope this gets fixed super quick because it makes it seem like V3 is just plain broken if you don't know that this is the culprit.
calus
This issue is fixed in OctaneRender for Maya 3.05.3 - 9.23
Pascal ANDRE
Return to “Bug Reports”
