C4D Command Line - VDB object - Error
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
teeshiiddo
Hello
I'm rendering via C4D Command Line R18 using a render manager. But I can replicate the issue directly in command line.
The only thing that is causing the issue is the octane VDB object, not the VDB file it'self.
Here is a scene attach, super simple with just a VDB object and bunny cloud file
Error message:
TBB: A function is called while TBB library is not loaded
TBB: Aborting…
OpenGL root context initialized
Vendor : NVIDIA Corporation (NVIDIA)
Renderer : Quadro 4000/PCIe/SSE2
OpenGL version: 4.5.0 NVIDIA 376.33
Driver version: 376.33
Vendor : VMware, Inc. (VMWARE)
Renderer : Gallium 0.4 on llvmpipe (LLVM 3.7, 128 bits)
OpenGL version: 3.3 (Core Profile) Mesa 11.0.3
Driver version: 11.0.3
Loaded Octane DLL:OctaneRender 3.05.1 version:3050100
Octane Render for Cinema 4D 3.05.1
Octane Render SDK version: 3.05.1
Application start : 01/12/17 at 17:23:19
Executable : 64 Bit
Version / Build : 18.039 / RB183317
Debugger : not available
Memory model : release
Startup path : file:///C:/Program Files/MAXON/CINEMA 4D R18
Application path : file:///C:/Program Files/MAXON/CINEMA 4D R18/Commandline.exe
Application executable : file:///C:/Program Files/MAXON/CINEMA 4D R18/Commandline.exe
Resource path : file:///C:/Program Files/MAXON/CINEMA 4D R18/resource
Module path(s) : file:///C:/Program Files/MAXON/CINEMA 4D R18/modules
Temporary path : file:///C:/Users/TC_Z800/AppData/Local/Temp
Prefs path : file:///C:/Users/TC_Z800/AppData/Roaming/MAXON/CINEMA 4D R18_62A5E681
Global Prefs path : file:///C:/Users/TC_Z800/AppData/Roaming/MAXON
OS version : Windows 10, 64 Bit, Professional Edition N (build 14393)
Processor : 12(24)x Intel Xeon CPU X5670
Computer name : Z800
Thread Count : 24
Cpu Speed (MHz) : 2930.000
Application Type : Modular
Octane VDB.zip
(74.02 MiB) Downloaded 350 times
Asus X99 10G WS | Windows 10.0 | 6x GTX 1080 Ti + 2x 2080Ti | i7-6850K CPU @ 3.60GHz | 32GB RAM
Pls try on previous. Its about activation pattern change. Post version related issues in related topics.
teeshiiddo
Thanks so much aoktar! That seems to have fixed it, should I update to the latest versions or wait for a fix?
And sorry I didn't realise it was version related, next time will post in related topic.
I used this version:
Octane Render for Cinema 4D 3.04.5-R2
Octane Render SDK version: 3.04.5
2017-01-12 21:27:52: 0: STDOUT: Application start : 01/12/17 at 21:27:52
2017-01-12 21:27:52: 0: STDOUT: Executable : 64 Bit
2017-01-12 21:27:52: 0: STDOUT: Version / Build : 18.039 / RB183317
2017-01-12 21:27:52: 0: STDOUT: Debugger : not available
2017-01-12 21:27:52: 0: STDOUT: Memory model : release
2017-01-12 21:27:52: 0: STDOUT: Startup path : file:///C:/Program Files/MAXON/CINEMA 4D R18
2017-01-12 21:27:52: 0: STDOUT: Application path : file:///C:/Program Files/MAXON/CINEMA 4D R18/Commandline.exe
2017-01-12 21:27:52: 0: STDOUT: Application executable : file:///C:/Program Files/MAXON/CINEMA 4D R18/Commandline.exe
2017-01-12 21:27:52: 0: STDOUT: Resource path : file:///C:/Program Files/MAXON/CINEMA 4D R18/resource
2017-01-12 21:27:52: 0: STDOUT: Module path(s) : file:///C:/Program Files/MAXON/CINEMA 4D R18/modules
2017-01-12 21:27:52: 0: STDOUT: Temporary path : file:///C:/Users/TC_Z800/AppData/Local/Temp
2017-01-12 21:27:52: 0: STDOUT: Prefs path : file:///C:/Users/TC_Z800/AppData/Roaming/MAXON/CINEMA 4D R18_62A5E681
2017-01-12 21:27:52: 0: STDOUT: Global Prefs path : file:///C:/Users/TC_Z800/AppData/Roaming/MAXON
2017-01-12 21:27:52: 0: STDOUT: OS version : Windows 10, 64 Bit, Professional Edition N (build 14393)
2017-01-12 21:27:52: 0: STDOUT: Processor : 12(24)x Intel Xeon CPU X5670
2017-01-12 21:27:52: 0: STDOUT: Computer name : Z800
2017-01-12 21:27:52: 0: STDOUT: Thread Count : 24
2017-01-12 21:27:52: 0: STDOUT: Cpu Speed (MHz) : 2930.000
2017-01-12 21:27:52: 0: STDOUT: Application Type : Modular
2017-01-12 21:27:52: 0: STDOUT: Command line arguments : "-nogui" "-DeadlineConnect 64433 772723021091"
2017-01-12 21:27:52: 0: STDOUT: Loading file:///C:/Program Files/MAXON/CINEMA 4D R18/modules/c4dplugin.xdl64 with module(s) net.maxon.c4dplugin net.maxon.c4d.c4dplugin
2017-01-12 21:27:52: 0: STDOUT: Loading file:///C:/Program Files/MAXON/CINEMA 4D R18/modules/crashhandler.module.xdl64 with module(s) net.maxon.crashhandler
2017-01-12 21:27:52: 0: STDOUT: Loading file:///C:/Program Files/MAXON/CINEMA 4D R18/modules/crypt.module.xdl64 with module(s) net.maxon.crypt
2017-01-12 21:27:52: 0: STDOUT: Loading file:///C:/Program Files/MAXON/CINEMA 4D R18/modules/drawport_general.module.xdl64 with module(s) net.maxon.drawport_general
2017-01-12 21:27:52: 0: STDOUT: Loading file:///C:/Program Files/MAXON/CINEMA 4D R18/modules/drawport_opengl.module.xdl64 with module(s) net.maxon.drawport_opengl
2017-01-12 21:27:52: 0: STDOUT: Loading file:///C:/Program Files/MAXON/CINEMA 4D R18/modules/drawport_selector.module.xdl64 with module(s) net.maxon.drawport_selector
2017-01-12 21:27:52: 0: STDOUT: Loading file:///C:/Program Files/MAXON/CINEMA 4D R18/modules/gui.module.xdl64 with module(s) net.maxon.gui
2017-01-12 21:27:52: 0: STDOUT: Loading file:///C:/Program Files/MAXON/CINEMA 4D R18/modules/image.module.xdl64 with module(s) net.maxon.image
2017-01-12 21:27:52: 0: STDOUT: Loading file:///C:/Program Files/MAXON/CINEMA 4D R18/modules/math.module.xdl64 with module(s) net.maxon.math
2017-01-12 21:27:52: 0: STDOUT: Loading file:///C:/Program Files/MAXON/CINEMA 4D R18/modules/mesh.module.xdl64 with module(s) net.maxon.mesh
2017-01-12 21:27:52: 0: STDOUT: Loading file:///C:/Program Files/MAXON/CINEMA 4D R18/modules/misc.module.xdl64 with module(s) net.maxon.misc
2017-01-12 21:27:52: 0: STDOUT: Loading file:///C:/Program Files/MAXON/CINEMA 4D R18/modules/network.module.xdl64 with module(s) net.maxon.network
2017-01-12 21:27:52: 0: STDOUT: Loading file:///C:/Program Files/MAXON/CINEMA 4D R18/modules/opencl.module.xdl64 with module(s) net.maxon.opencl
2017-01-12 21:27:52: 0: STDOUT: Loading file:///C:/Program Files/MAXON/CINEMA 4D R18/modules/opensubdiv.module.xdl64 with module(s) net.maxon.opensubdiv
2017-01-12 21:27:52: 0: STDOUT: Loading file:///C:/Program Files/MAXON/CINEMA 4D R18/modules/render.module.xdl64 with module(s) net.maxon.render
2017-01-12 21:27:52: 0: STDOUT: Loading file:///C:/Program Files/MAXON/CINEMA 4D R18/modules/shaderbase.module.xdl64 with module(s) net.maxon.shaderbase
2017-01-12 21:27:52: 0: STDOUT: Loading file:///C:/Program Files/MAXON/CINEMA 4D R18/modules/triangulation.module.xdl64 with module(s) net.maxon.triangulation
2017-01-12 21:27:55: 0: STDOUT: OpenGL root context initialized
2017-01-12 21:27:55: 0: STDOUT: Vendor : NVIDIA Corporation (NVIDIA)
2017-01-12 21:27:55: 0: STDOUT: Renderer : Quadro 4000/PCIe/SSE2
2017-01-12 21:27:55: 0: STDOUT: OpenGL version: 4.5.0 NVIDIA 376.33
2017-01-12 21:27:55: 0: STDOUT: Driver version: 376.33
2017-01-12 21:27:55: 0: STDOUT: Vendor : VMware, Inc. (VMWARE)
2017-01-12 21:27:55: 0: STDOUT: Renderer : Gallium 0.4 on llvmpipe (LLVM 3.7, 128 bits)
2017-01-12 21:27:55: 0: STDOUT: OpenGL version: 3.3 (Core Profile) Mesa 11.0.3
2017-01-12 21:27:55: 0: STDOUT: Driver version: 11.0.3
2017-01-12 21:27:56: 0: STDOUT: loading plugin directory: C:\Users\TC_Z800\AppData\Local\Thinkbox\Deadline8\slave\Z800\plugins\5877e6c1b2cfc91b947fe261
2017-01-12 21:27:57: 0: STDOUT: Loaded Octane DLL:OctaneRender 3.04.5 version:3040500
2017-01-12 21:27:57: 0: STDOUT: Octane Render for Cinema 4D 3.04.5-R2
2017-01-12 21:27:57: 0: STDOUT: Octane Render SDK version: 3.04.5
2017-01-12 21:28:06: 0: STDOUT: X-Particles running on Command Line Render.
2017-01-12 21:28:06: 0: STDOUT: ----------------------------------------
2017-01-12 21:28:06: 0: STDOUT: X-Particles particle system successfully loaded
2017-01-12 21:28:06: 0: STDOUT: X-Particles Build 3.5.0391 Release
2017-01-12 21:28:06: 0: STDOUT: Thu Sep 15 11:40:31 2016
2017-01-12 21:28:06: 0: STDOUT: Copyright (c) INSYDIUM LTD
2017-01-12 21:28:07: 0: INFO: Received Token: 772723021091
2017-01-12 21:28:07: 0: INFO: Connected to Cinema 4D
2017-01-12 21:28:07: 0: STDOUT: Appending "C:/DeadlineRepository8/submission/Cinema4D/Main" to system path to import SubmitC4DToDeadline module
2017-01-12 21:28:07: 0: STDOUT: Loading Scene: C:\Users\TC_Z800\Desktop\0117_Barclays_Center\01_Cinema4D\SmokeBlood_C001_v03.c4d
2017-01-12 21:28:11: 0: INFO: Loaded Scene
2017-01-12 21:28:11: 0: Done executing plugin command of type 'Start Job'
2017-01-12 21:28:11: 0: Plugin rendering frame(s): 0-4
2017-01-12 21:28:11: 0: Executing plugin command of type 'Render Task'
2017-01-12 21:28:11: 0: INFO: Render Tasks called
2017-01-12 21:28:11: 0: INFO: Pre Build Script
2017-01-12 21:28:11: 0: INFO: Rendering main output to network drive
2017-01-12 21:28:11: 0: STDOUT: Running Script: C:\Users\TC_Z800\AppData\Local\Thinkbox\Deadline8\slave\Z800\jobsData\5877e6c1b2cfc91b947fe261\thread0_tempCBalZ0\c4d_Batch_Script.py
2017-01-12 21:28:14: 0: STDOUT: Rendering frame 0 at <Thu Jan 12 21:28:14 2017>
2017-01-12 21:28:19: 0: STDOUT:
2017-01-12 21:28:19: 0: STDOUT: FRAME 0 fps:30 camMb:0 objMb:0
2017-01-12 21:28:20: 0: STDOUT: docFrame:0 edRender:0 curFrame:0 From:0 To:4 rFps:30 docFps:30
2017-01-12 21:28:20: 0: STDOUT: Total time:209.595 ms. Estimated time:167.676 ms.
2017-01-12 21:28:20: 0: STDOUT: Calculation completed.... frames:[0-5]
2017-01-12 21:28:20: 0: STDOUT: CRITICAL: Stop [gui_emuwindow.cpp(44)]
2017-01-12 21:28:20: 0: STDOUT: --------------------------- EXPORT LOG ---------------------------
2017-01-12 21:28:25: 0: STDOUT: Export materials time= 4730.152 ms
2017-01-12 21:28:25: 0: STDOUT: Collect objects time= 0.854 ms
2017-01-12 21:28:25: 0: STDOUT: Mesh creation time = 321.829 ms.
2017-01-12 21:28:25: 0: STDOUT: Triangles:0 Disp.triangles:0 Hairs:0 Meshes:0
2017-01-12 21:28:25: 0: STDOUT: VRAM used/free/max:349Mb/2.035Gb/3Gb
2017-01-12 21:28:25: 0: STDOUT: Out-of-core used:0Kb total used RAM:13.365Gb
2017-01-12 21:28:25: 0: STDOUT: Total export Time = 5062.43 ms
2017-01-12 21:28:30: 0: STDOUT: movable:0 Nodes:53 camMb:0 objMb:0
2017-01-12 21:28:30: 0: STDOUT: Device:0 TotMem:3Gb rtData:682Mb film:14Mb geo:66Mb node:10Kb tex:576Mb unavailable:668Mb temperature:79
2017-01-12 21:28:30: 0: STDOUT: Device:1 TotMem:3Gb rtData:682Mb film:14Mb geo:66Mb node:10Kb tex:576Mb unavailable:598Mb temperature:41
2017-01-12 21:28:30: 0: STDOUT: Device:2 TotMem:3Gb rtData:682Mb film:14Mb geo:66Mb node:10Kb tex:576Mb unavailable:598Mb temperature:42
2017-01-12 21:28:30: 0: STDOUT: Device:3 TotMem:3Gb rtData:682Mb film:14Mb geo:66Mb node:10Kb tex:576Mb unavailable:598Mb temperature:42
2017-01-12 21:28:30: 0: STDOUT: Device:4 TotMem:3Gb rtData:682Mb film:14Mb geo:66Mb node:10Kb tex:576Mb unavailable:578Mb temperature:35
2017-01-12 21:28:37: 0: STDOUT: Rendering frame 1 at <Thu Jan 12 21:28:37 2017>
It happened because of changes on activation process. Find latest build 3.05.3 now.
Return to “Bug Reports”
