Category: MATERIAL NODES
1) Renaming of material slot when LivePreview (LP) is working causes that further changes inside this material are not visible in LP - LP restart is needed
2) In textures nodes - opening file by Open File ICON when LP is working causes stop of LP ( frame with transparency checker is visible but no render pending ) - LP restart is needed
3) Cannot expose outside the group any properties of inside nodes
Category: 3D Viewport
4) This is not a bug but my modest request:
Implement please as a professional coder script that I have created that gives diffuse colour to material slots in 3d viewport into final version of BOE: viewtopic.php?f=32&t=57919#p298081
( I could not make interaction - changing slot causing color change that is already set for 3DViewPort diffuse )
Thank you.
Small Annoying Bugs part1
C. RAM Capacity (i.e. 6 GB)
Yes, I second that!
System – Windows 11
System – Windows 11
@JimStar
Number 2) seems to be fixed in 21 release - now texture loading makes shaders update
Thank you!
Is there any chance to fix the rest of the list ?
EDIT: Unfortunately for some textures ( 4K res images in my case ) I does not work as it should.
To make it work after choosing a file I have to push the Open button again and press Cancel in File Open Dialog. Then Updating Shaders is processing.
Thank you!
Be patient for me, please. I am new here.
