OctaneRender® for Maya® 3.05.2 - 9.20 [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems, 2015, 2016, 2016.5 and 2017 64-bit on Linux operating systems, and 2016, 2016.5 and 2017 64-bit on OSX operating systems (including and above 10.9).
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of Octan eRender™ Standalone on your machine.
viewtopic.php?f=24&t=58323
  • Implemented older Maya versions support for Linux and OSX.
Windows
DOWNLOAD
OctaneRender for Maya 9.20
OctaneRender for Maya DEMO 9.20
Linux
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 9.20 Linux
OctaneRender for Maya DEMO - 9.20 Linux
OSX
Installation:
- Just run the autoinstaller file.
DOWNLOAD
OctaneRender for Maya - 9.20 OSX
OctaneRender for Maya DEMO - 9.20 OSX
calus
I noticed the "height" attribute slider of the octaneDisplacement node have been fixed in a previous version :)
But the "mid level" attribute was forgotten in the process, same problem: unusable slider because of the insane Min/Max values...
Pascal ANDRE
