Render Failure!!! Check Console...
roinigo
Hello,
I get this message when i try to render in the live viewer : "Render Failure!!! Check Console window and Octane log window."
The Log says :
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
Triangles:12 Disp.triangles:0 Hairs:0 Meshes:1
VRAM used/free/max:1Mb/65Mb/4Gb
Free VRAM is too low!
Try to decrease polygon counts and use out-of-core for textures.
Use 'render instances' when it's possible.'
I tried with a simple cube. Same message.
Any ideas, please ?
Fab
ASUS PRIME X470-PRO
AMD Ryzen 7 2700X 8 cores
Noctua NH-U12S SE-AM4
G.SKILL FLARE X SERIES 64 GO (4X 16 GO) DDR4 2933 MHZ CL16
RTX 2080 Ti + GTX 980
Seasonic PRIME 1000 W Gold
Fractal Design Define R6
Are you sure that everything is fine?
roinigo
...what do you mean ?
ASUS PRIME X470-PRO
Accounts/drivers/gpus/etc...
Are you sure you can see some recognised gpu in devices section?
roinigo
...Everything is working now. :|
I just don't understand what's happened...
Hope it will stand like it.
ASUS PRIME X470-PRO
