HDR lighting in ORC ?
Discussion forum for OctaneRender Cloud
pxlntwrk
i'm currently testing ORC to see if i can use it seamlessly in production .
And after some tests i can notice that " Hdr lighting" don't react like in Octane Pluggin/standalone.
Here is an example scene HDR lighted only (ORC not render the same):
Octane C4D pluggin
Octane Standalone
Octane ORC
and here same scene lighted by Aera Lights Only ( 3 results are identical):
Octane C4D pluggin
Octane Standalone
Octane ORC
What i'm doing wrong ?
thanks in advance
PS/ same behaviour with Hdr in "linear mode", camera/BufferType
pxlntwrk.net
hi,
it's a long time that I don't use HDR Light Studio, but if I remember well, you should be able to bake the composed HDR in a normal single file.
In the last c4dOctane version, an .orbx file is saved and you can open it firstly with Standalone before sending it to ORC.
fuzzybro
Hi pxlntwrk,
Could you please describe your flow of sending this scene to the Cloud?
Vladimir
ORC Team
pxlntwrk
and thanks for answering,
@beppe: its not HDRI Light Studio , its simply an HDR file in in the env tag.
@FuzzyBro: my flow:
>working with c4d pluggin
>exporting to standalone by export animated .orbx
>checking my scene in standalone (everything is right there)
>uploading scene by standalone
>opening ORC by standalone
>checking the setup in ORC
>rendering in ORC
et voila
and the 2 scene are uploaded in my ORC
PXL_Render_Bal_Test_ORC_Spots (aera lights)
PXL_RB_ORC_Test_01 (HDR env.)
and heres a link to my .orbx (hdr scene) file
https://we.tl/gOrEnMjNGB
thanks
Cedric
pxlntwrk.net
fuzzybro
Hi Cedric,
What version of Octane is being used with Cinema4D and what version of Octane Standalone? We need that info to run some tests.
Could you also try using the web upload (go to orc.otoy.com/scenes and upload the ORBX file directly)?
Vladimir
pxlntwrk
thanks for answering evrywhere ;)
the version used for the render ball scene is 3.05.1 for Standalone and C4d pluggin
i'will try later with net upload.
Since every things seems fine without hdr.
Cedric
pxlntwrk.net
Return to “OctaneRender Cloud”
