x-particles
hringl
Hi
I use c4d and x-particles(full versions) and would like to use the octane plugin , have the octane demo installed
Is there an option to access particle paramters like temperature, mass in the material node editor?
eg if I want to map particle mass on a color spectrum in a material?
thanks
helmut
Hi hringl,
no, it is not possible to work in the node graph with volumes materials in c4doctane, but you can use an octane object tag in particle voxel mode and play with the volume medium node. Look at this example material by brasco in another discussion:
viewtopic.php?f=30&t=53750&start=10#p272509
