displacement map: "edge fill"
Murlon
Hello everyone
This is my first post here and I'm gonna keep it short. I'm working with the octane plugin for Cinema4D.
I'm currently working on a project where I put a displacement map ( 16bit.png made in world machine) on top of a cylinder with a polygon selector. However, I want the cylinder to look like it was a "cutout" of a landscape, so the edges of the cylinder must be connected to the displaced part. I have no idea how to do this and I've tried everything I could think off. Heres a screenshot:
I'm very grateful for every suggestion and looking forward to your answers!
Kind regards
Marlon
It's not a plugin issue. I'm sure Octane developpers are aware of.
Murlon
aoktar wrote:It's not a plugin issue. I'm sure Octane developpers are aware of.
Thanks for the reply. I know that this isnt a bug, its just how displacement behaves. I just wanted to know if there is any way you could achieve the effect I am looking for?
We can check that if you post height map for a solution. So it can be work-around for similar questions.
tschwenke
You can fill in holes by this method: viewtopic.php?f=79&t=57313
Best wishes,
Thomas
http://www.thomas-schwenke.me
Houdini 20.5 || Win11 || i7 + RTX3080
mikeadamwood
Why don't you use a C4D displacer on the cylinder instead of an octane one? That way you can control it with falloff..
Better still if you have Zbrush you could use the height map from WM as an alpha and use it on the end of a cylinder.
(Click to view gif)
Windows 11 Pro | ASUS Pro WSX80E | AMD Threadripper Pro 5975WX 32-Core | 256GB Micron 8x32GB 3200MHz ECC | 2x PNY RTX6000 ADA
Return to “User requests”
