An Octane error has occured [SOLVED]
marek
Every time the Archicad texture uses picture, an error appears.
Cuda log, just some lines:
Started logging on 22.12.16 12:05:57
OctaneRender 3.04.5 (3040500)
Could not load 'C:\Program Files\GRAPHISOFT\ArchiCAD 19 INT\ArchiCAD Library 19\Surface Catalog 19.lcf\Surface Catalog 19\[TImg] Textures 19\Brick 19\Brick Running Alpha GS.jpg:rgba'.
Could not load 'C:\Program Files\GRAPHISOFT\ArchiCAD 19 INT\ArchiCAD Library 19\Surface Catalog 19.lcf\Surface Catalog 19\[TImg] Textures 19\Wall Finishes 19\Plaster-Stucco 19\Textured Render White 01 GS.png:rgba'.
Could not load 'C:\Program Files\GRAPHISOFT\ArchiCAD 19 INT\ArchiCAD Library 19\Surface Catalog 19.lcf\Surface Catalog 19\[TImg] Textures 19\Concrete 19\Concrete 4X4 Alpha GS.png:rgba'.
Could not load 'C:\Program Files\GRAPHISOFT\ArchiCAD 19 INT\ArchiCAD Library 19\Surface Catalog 19.lcf\Surface Catalog 19\[TImg] Textures 19\Stone 19\Limestone GS.jpg:rgba'.
I work on local AC but as you can see the same error relates to INT version.
Any way to fix it, please?
Marek
AC 19 Windows 7 Pro
marek
And following the Manual:
'“File”->”Libraries and Objects””Extract a Container”. Select whichever your current library is (which contain the tree texturemap) – most likely “C:Program FilesGRAPHISOFTArchiCAD 16ArchiCAD Library 16ArchiCAD Library 16.lcf”. Extract into you My DocumentArchiCAD 16 Library folder (or similar)'
- I've got another error reporting that 'Extracting a Container fails' after I pointed my *Library19.lcf.
marek
OK, never mind.
I've tried to extract it to restricted folder on C:.
Chosen another location and all is fine.
Just posting a message here inspires... Well :)
Thanks Marek
