2 GPUs Slower than 1
Area for student license holders to post questions and discuss octane.
Drevangough
Hey Guys,
I'm using octane with C4D.
Running into an issue where 1 GPU renders a frame in the same time it takes two to render.
I have a 780 6gb and a 780ti 3gb.
Priorities have been set to high.
I was hoping than when I set both to render I could at least shave off maybe half the time but nothing improves.
I know the system will use the lowest common denominator when it comes to vram.
Is there anything else I need to know about?
Thanks for any advice/help.
Hi Drevangough,
maybe overheating?
Can you share more info about the specs of the machine?
Like:
B. Graphics Card(s) model (i.e. GTX 980 - 4GB, TITAN, etc.)
RAM Capacity (i.e. 6 GB), CPU (i.e. i7 5930k), Motherboard (i.e. ASUS Z99-WS)
E. OctaneRender Standalone version, if installed (i.e. 3.03.2, 3.04.3, etc.)
F. OctaneRender plugin version (i.e. v3.03.1-R1 - 3.04.3)
In particular, what is the exact model of the GPUs?
glimpse
Strange, could You please run OctaneBench & fire up two instances of GPUZ (free program You can get from internet)? simply open sensor tab of GPUZ for both GPUs (choose in the bottom) - we'll take a look what happens on a hardware level while Your cards are under load.
