Environment input pipe
RobotRumpus
One thing I would like to see is an input pipe in the Octane render node to plug an image or procedural environment into the Environments node.
thanks,
~Jason
Robot Rumpus.com
Hi - I missed this post, so sorry for the delay.
I looked into having Nuke nodes plug into the OctaneRender node as an Environment when writing the plugin. However I could not see any advantage over the current system where you edit the Environment via the Octane scene. Nuke nodes such as ColorBars and ColorWheel will not work as an Octane Environment. However a Read node would - but I'm not sure it offers any benefit over setting the HDR image map inside the Octane Environment node yourself (where you get more flexibility to tweak settings). Happy to hear an opposing view.
RobotRumpus
I see. Well, I don’t have a whole lot of experience with this yet, but here is my thinking…
- One issue I have had is when I open up a script elsewhere on the network or on a different operating system, the Nuke read nodes auto-localize the read path, so my scripts open up perfectly under mac or windows, and in different places on the network if shots get moved around. However, the Octane environment input always breaks and has to be reset. If it were governed by a Nuke read node instead, that wouldn’t happen.
- Another advantage would be that it would be useful to use Nuke resources to live-color-correct, filter, or otherwise process images or animation going into the environment node. I am speculating, since I have not needed to do that yet, but I can see that being an advantage.
Thanks so much for you help! It is much appreciated!
~Jason
I will see if I can implement this in the next release.
I have spent some time trying to implement this request. It either needs to be done by converting the Nuke Environment Map Read node path string to an actual OS path (which the Nuke API does not appear to do), or by getting the actual IBL bitmap from the Nuke Environment node and loading it into Octane (also not trivial). So in summary, this is possible, but complex. So I have not been able to implement it yet - but I will keep looking at it as time permits.
Return to “User Requests”
