OctaneRender™ for Blender 3.05t3 - 11.16 [OBSOLETE]
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions.
  • New 3.05 test 3 engine integrated. This engine version tests rounded edges functionality changes.
  • Fixed "server exiting" bug.
  • Improved Blender's LiveDB preview-icons rendering.
  • Minor fixes and improvements...
Note: After installing of this version you may need to clear the server's and Blender's LiveDB caches. Easiest way - to delete everything inside livedb folders in user directory and in Blender's user-data directory. Server will need at least 10 minutes (depends on your connection speed) to refresh the LiveDB cache, during which LiveDB will not be functional from Blender UI.
You can read about new features of OctaneRender™ 3.0 here:
viewtopic.php?f=33&t=51679
1. OctaneRender™ Server
If you need to see the changelog of current rendering core, or download standalone installer to get network slave and daemon please find it here:
viewtopic.php?f=33&t=57897
Windows
Blender Octane Edition - 11.16 (2.78a)
Octane Server - 3.05t3 - 11.16
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v11.16 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v11.16 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v11.16 OSX ZIP
Please, if you decided to report a bug:
- Don't post in Blender section the reports about how Octane engine works - use the Octane Standalone forum sections for that.
- Give a meaningful description about what you think is wrong and how to reproduce it (in addition to screenshots if any). I can't solve the "one screenshot" rebuses without any meaningful description...
- If you use Google-translator to post here - check please what you got before posting it, and edit it before posting. Ask your friends to check it if you don't speak English.
