Blender "Diffuse" Color in Viewport
sinesium
Hi
does anybody know how to add a color to object solid mesh for specific material slot ?
When there is no Diffuse Shader then color is always white.
Be patient for me, please. I am new here.
sinesium
JimStar,
is it possible to add "Diffuse" colour for every material slot based on Output node?
Output node should have colour picker field to select colour that shown in the 3d Viewport for mesh that has this material attached:
bpy.data.materials["<MATERIAL_NAME>"].diffuse_color
Could you think about this feature ?
sinesium
I made simple script ( I am python rookie ) for changing color for object in selected material - it changes color in viewport to RED.
It changes colour for every FACE of every object that has attached this material name. This is what I need :)
Currently I do not know how to build a additional panel in Materials to select colour by Color Selector.
I will try to find out how to create it.
Now you can run it from text editor:
import bpy
print (bpy.context.object.active_material.name)
bpy.data.materials[ bpy.context.object.active_material.name ].diffuse_color=(1,0,0)
sinesium
Ok. I made it.
My own script that helps to change Diffuse Material Colour.
I did not make __init script for install from zip.
Just unpack and install by directly picking a file 3dViewMatColor.py
After installation it appears in Material tab panel named 3D Viewport Material Colour
Let it make you work easier !
3DViewportMaterialColor.zip
(838 Bytes) Downloaded 362 times
J.C
Thanks, super useful :) I wish it worked automatically by taking the color from the diffuse input of a material node :)
System – Windows 11
sinesium
I think it is better to have possibility to set it manually. Cause sometimes is very needed to mark material in scene with specific colour.
J.C
There coluld be a swich manual/auto viewport color assign ;)
System – Windows 11
zukan
Very useful, thank you sinesium!
MacOS Sierra 10.12.3 - GTX 970 + GTX 780 Ti - 16 GB RAM - Nvidia Driver: 367.15.10.35f01 - Octane Blender 3.05.3 - 11.23 - Blender 2.78a
Return to “Blender”
