OctaneRender® for Maya® 3.04.5 - 9.8 Linux [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Version 2017 64-bit on Linux operating systems.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
  • Fixed multimaterial crash in cases when some material gets deleted.
  • Minor fixes and improvements...
Known issues:
- batch rendering on OSX is not working currently. This is Octane engine related issue, will be fixed in next SDK.
- Octane SDK 3.04.5 may crash sometimes when using LiveDB. Should be fixed with next SDK version.
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 9.8 Linux
OctaneRender for Maya DEMO - 9.8 Linux
viewtopic.php?f=24&t=57660
Yours,
The OctaneRender™ Team.
